shaw520
- Joined
- Aug 27, 2009
- 634
88' Searay 230 single 5.7 mercruiser, Alpha 1 gen..... motoring back to our home dock at about 2k rpm, boat full of people and gear, off plane but pushing a lot of water and all of the sudden it felt like it popped out of gear,... brought the stick back to neutral,.trying fwd/rev gears, nothing! Got a buddy to tow me back, removed outdrive expecting to see broken U-joint, nope,.. pulled cap of outdrive to inspect upper pinion gear, everything in tact, drained outdrive fluid, everything normal, no metal or water. Check engine coupler with another outdrive shaft that I have from an old alpha, coupler seems fine. Checked shift cable operation with helm stick, normal. I now have the outdrive on the bench and I can engage fwd and reverse with no gear slippage. WTH??? Baffled,.... what next ??
