need help with engine identification
mcmarcia
Hello, I just bought my first powerboat and am not sure on the engine and am a bit confused trying to id it. It is a 150 HP v6, 2 stroke, carbed,merc w/ serial number 0G541105. The PO told me it was a 1997 engine which had a full powerhead rebuild in 2005 ($2800 of reciepts). Just trying to make sure I know which of the half dozen 150 HP motors they built back then so I can order the proper parts and such and know what I have. They certainly make it confusing for the newbies. Thanks for any help.
carholme
Re: need help with engine identification
It comes up as:
150 V-150 V6 0G451461 0G594012 1997 USA
From here:
http://www.marinshopen.se/Motorer/O...Mercury2taktV6135175hp/tabid/490/Default.aspx
It is a model:
1150412TD MERCURY 1997 150
Parts listing:
http://www.crowleymarine.com/mercury-outboard/1678.cfm
Service Manual P/N: 90-824052R3
http://1manual.com/Mercury manuals/Service Manual PDFs/TwoStroke/824052r3/cover.pdf
You must have Adobe Acrobat reader installed to use this manual. If you scroll down to the lower part of the opening page, you will see the various engine components in red. Click on the one you want and when the first page opens, click on the "Save As" icon at the top LH corner of the page and you can save it to your computer.
Gerry
mcmarcia
Thanks for the great links. Now I know which motor I have. I really like this site. I will search the site to see if there are any common problems to look for and maintenance hints and such. I will save all this in my laptop for future reference. I am pretty good with parts for now, it came with a spare set of plugs (weird looking plugs) which I put in and a water impeller kit, clymer manual, two stainless steel props, and some other handy stuff.
