Need help with exhaust pipe to gimbal o-ring P/N
GaJeff
I have an 81 merc 4cyl. just got done doing a resto and putting the engine back in. Im having a hard time finding the P/N for my exhaust to gimbal o-ring. Al the ones ive found look like an upsidedown "U" and are for V engines with a Y pipe. I have a single pipe and my o-ring is an oval.
Does anyone know the P/N for the oval o-ring so I can get this thing ordered and move on?
Thanks, Jeff
achris
More fish than mountain goat
Re: Need help with exhaust pipe to gimbal o-ring P/N
There should be a groove for each (all 3) in the gimbal housing... If one of the small ones leaks, it'll fill the boat just as quick... :eek:
Chris.......
GaJeff
My pipe isnt big enough to cover the lower o-rings... Actually its just two holes at the bottom, no groove and the bolt holes look like they were never tapped for threads. My downpipe only has 3 bolts holding it in and it all fits perfectly over the hole.
Thanks for the P/N Jeff
GaJeff
I double checked my holes and the lower holes go nowhere... The o-ring in the link above should be the correct one right? I guess my downpipe is different because its a 4cyl? Also I assume the lower holes exit exaust out the side of the gimbal housing? Mine collects at the main and have 2 holes inside that route out the sides. I ordered o-ring #13 so hopefully it will be here in time for the weekend... Im so ready for a boat ride the wait is killing me
Jeff
muc
"Retired" Association of Marine Technicians...
Yes, you just need the one O-ring. The two small O-rings are only used on V-8 setups.
