Need help with fuse panel wiring
iraqvet13f
i need to add 2 additional circuits, totaling 8 amps. ( 3 gang breaker / rocker switch panel)( an extra just in case one goes to crap)
1 for a trailering spot light ( 2.5 amp actual, using a 5 amp circuit breaker rocker switch) very brief use
1 for my front fishfinder (3 amp actual, using 5 amp circuit breaker rocker switch)
my problem / question is: (Can’t seem to post photo of the fuse panel and neg bus)
my new boat has a factory fuse panel with attached negative bus, BUT, all positive terminals are taken.
I did notice a slotted metal tang at the top of the fuse pane, but not sure if I can add a jumper wire from the slotted area of the panel, adding a small bolt / nut, and run to my 3 gang breaker rocker switch’s. Combining the 3 rocker switches positives to the jumper wire for power, then combining all 3 the negatives into one groups as well and run to the negative bus.
Ayuh,.... Welcome Aboard,.... If the switches have their own breakers, you can tap off the wire from the battery to yer fuse panel, 'n parallel yer 2 new circuits that way,....
iraqvet13f
That’s what I was thinking about as well, considering they will have their own breakers, but wasn’t real sure. Thanks for the confirmation!,
Ayuh,.... 'n Thank You, for yer service to Our country,..... ;)
