biglurr54
- Joined
- Feb 14, 2011
- 234
I have a 1989 Evinrude 30HP outboard. I purchased the motor just recently to put on a small pontoon boat. The guy I bought the motor from said that he had a difficult time starting it but once it started it would run great. I looked to carb over and noticed that the electronic choke solenoid was squirting gas into the cowl. It appeared that the two hoses that attach at the bottom ad broken free and took the nipples with them. I got a good deal on the motor. I purchased a new faceplate for the choke solenoid that had the little hose barbs on it. The parts catalog shows one barb has a little plug on it for my motor. I purchased the plug as well. I installed everything as shown on the catalog. The old hose still had the broken off barb in it.
I put it all together and the motor still struggled to start but I could get it to start. The whole cowl was covered in oil and gas. I cleaned everything up with Purple power. I took the boat out for a ride and it struggled to get started. I had to take the cowl off and cover the carb throat with my hand to manually choke it. Once it was running it ran well. It has some stumbles and skips but I believe it needs new wires and plugs. After the boat ride, I noticed gas and oil in the water. I pulled the cowl and noticed that there was gas all over inside the lower cowl. The gas/oil was running down the cowl, out on the motor leg and into the water.
I believe I still have an issue with the choke solenoid. Im not sure what the issue is though, or where the gas is coming from. I do know that my symptoms are: No fuel on cold starts, and plenty of fuel in cowl after running.
Any ideas where / what to check for?
