NEED HELP WITH GAUGES 1981 GLASTRON-CARLSON C-500
Captain NEMO
hello guy my name is Daniel im in SAN ANTONIO TEXAS.
i have just gotten my hands on a GOOD 1981 Glastron-Carlson C-500 METRIC SERIES..its got a JOHNSON V4 115HP Outboard..
now my question is where can i find a wiring diagram of the gauges so i know what wires go where..?
i've got a FUEL, TRIM, RPM's, AND MPH. i need help figuring out what color wires go where...
engine runs great but i have not taken it out on the water yet..
im redoing the floor and little things here and there..
thank you and anyinfo would be great...
"WHAT EVER FLOATS YOUR BOAT"
Captain NEMO
Re: NEED HELP WITH GAUGES 1981 GLASTRON-CARLSON C-500
anyone please..
im trying to get the RPM'S to work and the TRIM to work also...
there are 3 wires coming from the control panel on the side under the key ignition they are BLACK PURPLE and GRAY...
then there are 2 wires coming of the handle for forward and reverse where the trim is locate and they also go under the dash and they are WHITE and BLACK..
on the gauge them self they both have a L for LIGHT and a I for IGNITION a G for GROUND and a S for SENDER..
my question is what goes where?
thank you...
Daniel
Dunaruna
[colour=blue]Hi Daniel, welcome to iboats.
Boat wiring is generic, that is to say that (generally speaking) the color codes for wiring is the same for all brands of boats. The exception to the rule is when someone has played with the wiring and messed things up, this is especially true in older boats that have had more than a few owners.
Repost your question in the 'electrics' forum, plenty of people there to help you (they probably don't look down here).
To get you started - from the control box, black is ground, purple is ignition positive and grey is the tach signal wire. On your RPM gauge - black to 'G', purple to 'I' and grey to 'S'. The 'L' is an option, it illuminates the gauge, you don't need to use it. If you want to use the light (or any other gauge light) just need to connect into the navigation light circuit (the same wire that powers the nav lights).
Captain NEMO
great thank you nice to meet you...
i will repost it in the electrical forum.. put what about the trim as for the 2 wire that are white and black. is black the ground and white sender?
thank you
Daniel
