Need help with Grease and Oil for Stern drive.
Bhaag05
I have a 1976 Gulfstream with a 175hp Electric shift stern drive I wanted to know which Oil and grease would be best to use.
southkogs
Re: Need help with Grease and Oil for Stern drive.
In your lower unit you need Type C gear lube (you can order it here on iBoats - you won't find it easily locally). For your upper and intermediate the standard 90w lube you can pick up anywhere will work. For grease I use the Coastal Marine grease I can pick up at the auto parts store here locally.
Bhaag05
Great thank you I will get that.
