need help with hardware on alpha drive
gwgautney
can anyone tell me what size bolts i need for bolting up the outdrive to the bellhousing. Need to know how long and diamater and what they are made of.. Bought boat and drive was already off of boat with no bolts.
achris
More fish than mountain goat
Re: need help with hardware on alpha drive
Those are studs, not bolts...
thumpar
Like achris posted, they are studs. It takes 5 washers (not normal thin flat washers) and 6 nuts for the drive to bellhousing. Then you have the pivot pin, 4 washers (2 different sizes) and 2 nuts for the trim rams on the drive side.
What exactly do you have at this point?
gwgautney
I just need the 6 stud and washers and nuts for them to mount outdrive I have the other hardware
gwgautney
Are these stainless?
Fun Times
No, they are chrome plated brass. If you use SS, you may have problems removing them later on. With this, my signature line says it all.
achris
Studs: 16-59579
Nuts: 11-134391
Washers: 12-35935
Chris.....
gwgautney
Is that the part numbers and where can I order them from
achris
Any Mercury dealer. Either 'walk-in' or on-line...
Yes, they are the part numbers.
