Need help with idle and WOT
Davis1995
I have a 1996 70hp Johnson and need help with my idle and wot. I have cleaned my carbs multiple times, replaced spark plugs, new coil pack for one cylinder..got the other 2 coming in this week. I am trying to figure out why my motor wants to shut off in neutral..very frustrating.
also, my engine runs fine until I get to WOT and then it wants to bog down and go in and out. My boat used to go 37-42 and now it won’t go over 28.
another question I have is about the amount of oil residue that builds up on the water line along the back of my boat. Anyone have problems with this? It’s a new thing to me
ecu1984
link and sync done on the carbs? when idleing are all three carb butterflies closed and at WOT are all three perfectly opened?
Davis1995
I have a friend of mine that has came and helped me look at everything. He just got done adjusted the carb idle screws this past week. From what I remember is that they are all closed and opened respectively. I’ve been fighting this all year but it works good enough lol
Do a compression test.----Just for future reference.----There have been issues with # 2 cylinder.
Davis1995
I think that’s the one that I had to change the coil pack on. I’ll check the compression..what do you do if it’s low?
If you had to / did clean the carburetors multiple times then maybe it was NOT a carburetor issue.----Simple trouble shooting will find out why there is a lack of power now !!----Test for spark as well.----Strong spark is what you want.----The system is capable of jumping a gap of 3/8" or more.
Davis1995
If compression is low on any cylinder you remove cylinder head to find out why.
Davis1995
Appreciate it. I actually had to change the top cylinder coil..we also did a spark test and had sparks in each cylinder
