frozenokie
- Joined
- Feb 4, 2008
- 309
I just got through rebuilding this motor from crankshaft up. I started it up today (with flush kit) and no problems, ran smoothly, responsive, etc. After about 10 minutes of just idleing and giving her tiny boosts of throttle, I shut it down using the start/stop switch. I then attempted to restart it. It did nothing at all
no "click" sound, no movement, or any sound at all. The lanyard still gives me the two short beeps as if everything is OK. I checked the battery - still at 12.6V. I visually checked the fuses and all are good. I also visually checked the coil and connections, the MPEM, wiring harnesses, and all looked to be fine.
The only thing I thought was suspect was that the regulator/rectifier was really warm to the touch. All the wiring is hooked up correctly so I don't know what to check or why the rectifier would be that warm
Does this mean that the recifier is burnt out? If it is, how do I check it to be for sure?
Has anybody experienced this before?
