Re: need help with ignition switch
Yeah, it helps a lot. The purple wire is attached to the correct terminal on the engine terminal board for tach signal. However, it should NOT be attached to any terminal on the ignition switch. As it stands now, the purple appears to be given AC power from the rectifier and depending upon switch terminal it is either receiving 12 volts from the battery or attached to the other "M" terminal---Wrong in either case.
I do not see a blue wire and that tells me that even if the engine would start, it would not shut down. SO: since there is no blue wire showing, if you do not have a tach or do not mind rewiring for it, remove the purple from the engine terminal board and re-connect it to the BLUE terminal (just above the ground. NOW Be certain that at the ignition switch the purple is connected to the other "M" terminal. (opposite white)
I also do not see a red in the cable attached to the red terminal on the engine, yet the red in the cable is attached to the "B" on the ignition switch. SO: From where is the power coming? I see another smaller red wire but can not see from where it comes or to where it goes. Be certain that the red wire in the cable is attached to the red terminal on the engine terminal board. That is the correct source of power for the switch. Right now you may be getting power from a circuit that simply can't supply enough for both choke and start circuits.
Let's see if that helps your problem!
BUT: As a caution-- I can not see if the wires connected to the switch are in the cable that runs from the engine. I do not see a blue, and I do not see an orange which are usully in the cable bundle. I do see a black, but I can not tell to what it is connected if at all.
SO; Before you go changing wires, trace the taped bundle and see if it is the engine cable or if the wires originate elsewhere. (Like inside the control box.) Something is just not quite right here.
Second looking seems to show ( now mind you I can not see the terminal itself) that the purple wire is connected to the ground terminal on the rectifier. As a stop circuit this will work, but it is not correct.
See my private message to you
