Need help with Lower end on 88 Evinrude 20 HP
kmcgillis
Had to tear down lower end because of **** problem. Anyway got new parts and now I can't get it to go back together, I have the manual and am trying to follow the intructions but they aren't to helpful. Problem I am having is the forward gear and the front bearing will not line up so I can't get the prop shaft to go into the bearing. It seams like to gear is not sitting all the way into the the pinion gear so the whole aren't lining up. Is there any trick to this or does anyone have any idea's. Also is there any trick to getting the shift lever to sit into the grove on the throw out bearing for shifting.
Thanks
