Need help with my '81 Century. Hasn't been in the water for 2+ yrs.
bbronco
1981 Century Cortez 270 LOA 26'<br /><br />it has not been in the water for over 2 years!!!<br />im puting a new motor and transen (sp) boot in it.<br /><br />what else to i need to do bc it has sat so long???<br />how do i change the boot?<br />what should i clean and replace in the out drive?<br />any help would be great!!!<br />Byron
bbronco
Re: Need help with my '81 Century. Hasn't been in the water for 2+ yrs.
ttt
Bob_VT
Change the water pump in the outdrive and change the outdrive oil.<br /><br />I would pay special attention to the state of the gas that may have been left in the carb and fuel tank. If the tank was left empty there may be rust and if it was left full there may be varnish.<br /><br />Go through the entire motor...carb, plugs, distributor, wires clean and replace ANY fuel filters.<br /><br />Lastly I would start it on water muffs before the maiden voyage. oh....don't forget the plug!<br /><br />Bob
bbronco
thanks for the reply!!!!<br />couple of questions<br />what are muffs?<br />how do i get the out drive down with out power???<br />i need it down so i can take it apart but have no idea how to do that?
stub756
there should bea trim switch on the throttle thay will lower it... the best thing you can do is get a manual for your engine.
bbronco
i know where the switch is!!! i don't have any juice in my batterys to move it!!! <br /><br />where would i go to get a book on the boat?
McKenzie
Is this an OMC? If it is, depending on what trim system you have, there is a manual release valve on the hydraulic pump.
bbronco
yes it is an omc!!! where is the pump?
