Need help with prop...
lp142
Apparently no one can help me in the prop section so I'll try it here. I have aquired a Mercury 1100, 110HP 1966 Model, Serial number 1935760, it does not have a propeller, I have no idea on what or where to get it, I'm lost on all these pitch and stuff, my boat is a closed bow 18 foot long, I don't plan on racing so all I need is a basic propeller.
Thanks
Yepblaze
Re: Need help with prop...
You could try looking it up here.
http://maxrules.com/propindex.html
Sometimes lower units get changed, so you may want to put a mark of some type on flywheel and prop shaft.
Then turn flywheel, and count rotations required to get one turn on prop shaft.
If the ratio is different from stock you will need to adjust pitch accordingly.
