Re: Need help with tachometer hook up.
The Service Manual states "Full Throttle Operating Range...4500 to 5500 rpm." <br /><br />It then adds: "Note....In order to get the best performance from your outboard the upper end of this range, from 5000 - 5500 R.P.M., is the engine speed to use in selecting the proper propeller. The R.P.M. should be measured with your expected average load in the boat."<br /><br /> Service Manual Part #506919, Page 2-2 <br /><br />I don't have a reference line for idle. My 115 1976 Johnson is set to idle in gear at 650 rpm, but it runs a little rough until it warms up while out of gear. I suppose it could be set higher but I don't want to hurt the gears. This is the orignal motor on my 1976 18' Starcraft and it will still take it to 40 in a hurry. I use an OMC 14 X 17 Aluminum prop if that helps, but the boat is aluminum alloy so it is about 1/3 lighter than a comparable fiberglass boat.
