goombadi99
- Joined
- Apr 11, 2010
- 23
2004 tracker targa 16ft
mer 50 2stroke 3 cyl
1400 lbs
wot 5200rpm @23 mph
My question is that the prop on the boat is pretty beat up. And the prop that is on the boat is a 10.5in diameter 13 pitch
Does this seem right? The lower unit has a tag that says gear ratio 1.83x1 ...12x22. does that mean I should have a 12in 22pitch prop on there?
I thought for sure that this boat should do closer to 30 mph. I just bought the boat from the original owner who said he never changed the prop since he bought it new. If I trim the motor up slightly i get 5500rpm but no mph change. Could the badly dinged up prop be the culprit, or the diameter and pitch be compepltely wrong?
Thanks for any help.
1400 lbs
wot 5200rpm @23 mph
