Stephen_555
- Joined
- Jan 12, 2010
- 14
recently a wire broke loose on my tilt and trim switch on the control handle. I re-attached the wire to the switch and nothing happened. so i thought maybe i had damaged the switch when i soldered the wires back on it. I replace the switch and still got nothing. the t/t switch on the motor works fine. could the relay allow one switch to work and not the other? is there a fuse in the wiring from the switch on the control handle that i'm missing? please help!!!
1990 Evinrude 48spl
1990 Evinrude 48spl
