I'll try and describe this as best as I could:Just picked up a new trim/tilt solenoid. In looking at the way the current one is wired , I noticed the ground wires{there are 2 solenoids} come off the small metal posts on each solenoid ,and the other ends go to the large rubber grommet on the solenoid. Inside the grommet is a metal sleeve. It seems strange that the grounds are mounted to the FRONT side of the grommets because the backsides have more metal contact , via the flat/flanged end of that metal sleeve. The front of the sleeve is just a normal end. When I put the new solenoid on should I mount the ground wires BEHIND the solenoid against the head and the larger area of the metal sleeve??
