Need help with wiring harness.
bleubeans
I posted over in the Johnson outboard repair section but never got a reply. Anyway, I have a 1986 70 hp Johnson. The previous owner eliminated the 20 amp fuse and i think that is why all the wires are "mushy"and wire exposed. This left both the male and female ends of the red plug burnt/melted and a prong just fell out when i unplugged them. I happened to have an old harness from a 83' evinrude 30 hp and I plugged it in and connected it everywhere except the black/yellow wire (key kill switch) because this harness didn't have that connector for whatever reason. So, i guess my question is: can i rig the black/yellow wire from the power pack so i can turn the motor off when i turn the key to the off position? Would I have to run that wire up the length of the harness to the control box and connect it to the switch (black/yellow) inside? Would this work? Or is there an easier method. Thanks in advance.
NYBo
Re: Need help with wiring harness.
Yes, yes, yes, and I don't think so.:)
