Need Help With Wiring Ignition Switch
whisker
HI,
My 87 150 black max 150 is currently on engine stand. i would like to hook up ignition switch on it while its on stand to check everything out. i still have the old half of the boat harness on it so all the wires are there. can anyone look at these pics and tell me what i need to do to hook up ignition? also what kind of ignition switch can i use just tempo for right now on stand.
Chris1956
Re: Need Help With Wiring Ignition Switch
You can start it without ign switch, just unplug wiring harness and work fuel enrichener manually, and jumper solenoid. if you want to use an ign switch, you need one that grounds to kill ign in the off position. Black is ground, Orange (or Black/yellow) is ign kill wire, red is battery, purple is ign accessory, yellow (or yellow/red) is starter solenoid, grey is tach (or maybe enrichener, depending on year)
whisker
hi chris,
any recommendation on ignition switch.
