need help
katbird
1976 inline six 1150 fuel pump<br />while putting new hoses on the fuel pump I can't remember which hose goes where. on the bottom there are two hoses left and right looking down at the pump and there are two fittings at the intake plate,one at the very bottom and one a little higher up and to the left of the intake. can anyone tell me which goes where. the manual does'nt show any diagrams.<br />thanks<br />also I found another flywheel with the timing decal and appreciate all the info on it.
Dwain B
Re: need help
Hey RR. I am not sure how far back my factory service manual goes. It says to serial #4112635 and up. If you have access to a fax machine you can look in my profile, get my email addy and email me the fax machine # and I'll try to run you a copy of the page and fax it to you. Of course...I'll have to get wifey to show me how to operate the fax machine. But according to the manual I'll try to explain it best I can. There is a plate the fuel pump is mounted to. The hose on the plate goes on the outside of the pump. The top hose on the pump goes to a fuel filter then to carbs. The bottom hose comes from the tank. Hope this helps.<br /> Dwain
Dwain B
Re: need help
Just had another thought (that would explain the headache). If no fax is available to you I can try to take a picture of the page and email it to you. It will lose some in quality but may be enough to help.<br /><br /> Dwain
