Lucky 1
- Joined
- Jun 17, 2010
- 10
I am about to go nuts here with this boat issue. Let me try and make this quick and clear. I have a 86 Sea Ray Seville mid cabin cruiser with a 4.3 mercruiser. Last year I started having trouble where after warm up and leaving the marina, I would open it up and the beast would start to sput and spit and backfire. Won't start. Found the carb filter plugged with black stuff. Clean and repeat several times. It would run fine for a day or 2 then do the same thing. Replaced the gas line after the water/fuel seperator because it appeared to be a air hose. Maybe the black stuff was coming from the hose. Worked and then it seemed that some gunk got passed the filter so I had the carb rebuilt. Well, it's a new year with the same old problem. Now when this happens, all I have to do is crack open the gas line at the filter and tighten back up again. Then it runs again. But now the filter is clean with no crud but still does the same thing. I was hoping I could finally enjoy the boat but it is becoming unlikely.
