2007 Merc 60 4 stroke. Ran the starting battery down. Used the trolling motor battery to get off the lake. Tilt worked until I recharged and replaced the starting battery. Now the gas gauge shows way over full and jumps a little when the key is off and I bump the tilt switch. The ignition doesn't even beep, and the tilt relays hum, but the tilt doesn't work. The battery shows fully charged and there's 12.86 volts on both sides of the 5 amp Smartcraft data bus circuit, and 20 amp main relay/accessories circuits, but no voltage at either the 20 amp fuel pump/ile air control/fuel injector, or 25 amp ignition coil circuit fuses. The only thing I've not tried yet is hooking up the trolling motor battery again.
Thanks for any help.
