Need help
Hooray
1989 Mercury 80hp 3cyl
how do I test the switch box, stator and trigger seem ok
Sylva-Ranger
What is the problem ? The best to test everything, You need a DVA adaptor and a good multimeter.
if only one cylinder do not fire, they are some test you can do without special equipment, but a DVA is the best.
Or try a know good one switch-box.
hl
There are several you tube sites. After reading in your repair manual about testing, check out a you tube site which will help understand what you have read.
