Re: Need helper wrench, Daytona Beach FL
Sorry I have been out of town so I have been unable to reply. I have tried everything that I know to do and have been on here many times trying to narrow it down. I can get it started eventually (usually) but then under power it just never gets into the higher RPM's. Then I had a problem with no power going to the ignition so rewired around it and got that going but not the right way. I have had problems with the Tilt and Trim. I drained refilled manually raised and lowered about 10 times let sit but it still will not work. The motor will run but it only moves like 1/4 inch. I think the engine just needs someone that knows something about it to take a look and work out the kinks. I know a little but not enough. I also am a little short on cash at the time. Which makes the 45 an hour kinda steep at most repair shops. Any ideas would be greatly appreciated. Thanks....
