Hi,
Between rough handling by marina forklift operators (damaging the transducer) and my own error in leaving the fishfinder in the sun too long (damage to screen), I'm due for a new fishfinder. I picked up a Raymarine L470 fishfinder. Before I embark on the replacement, I thought I'd post this thread to ask for helpful hints from those of you who have experience with this sort of thing. I'll mention a few areas of concern to prompt your thoughts:
The base for the LCD display for the previous fishfinder is not going to come off the center console dashboard easily. I already unscrewed the base, but it appears some kind of strong sealant was used. I tried using a razorblade around the edges of the base and a screwdriver to pry it off, to no avail. Suggestions?
The old transom mounted transducer and the cable need to come out. What's the best way to seal the old holes (where transom is attached)?
The 19'7" Neptune Sunbird doesn't leave a lot of room for running cables or getting a hold of things. I anticipate challenges with running the new cable from the console to the transom as it needs to meander through inaccessible, tight spaces. I'd imagine I want to attach the new cable to the old one and pull it through, but electrical tape probably won't suffice to keep the two cables together. Thoughts?
Regarding EMC guidelines, the insruction book says to allow plenty of space between wires for different electrical units. The transducer cable can't help but run near the VHF radio wire and the starter wire, so what do you suggest?
The new power cable includes a smaller shield wire for connection to a good ground. What would that "good ground" be? I think the approach with the new power cable is to some how connect it to the wire running to the console "accessories" fuse (rather than running it back to the battery).
Thanks for any tips...
