Re: need hepl on warter pump install
coolmavrick <br /><br />You really need a Manual for this one. It's a bit much to talk you through this one. The basics are, remove the lower unit to gain access to the pump, replace the impeller and/or housing and reassemble. Sounds easy enough, but there are other things that you need to know to complete the task properly. You can always ask back here if you run into problems. You can get a Factory Manual at most dealers or at the link below:<br /><br />
Manual
