need info about Evinrude 6 Yachtwin outboard
jebenstock
I have an Evinrude 6 Yachtwin outboard. Wanted to change spark plugs, but I do not have necessary information about engine for store people to choose the correct plugs. The only information I have is that the motor says:<br /><br />Evinrude 6 Yachtwin. The metal is metallic blue, and has a white plastic top;<br />model number is E6SLCOB<br />serial number is G0467690<br /><br />I need to know horsepower, year of engine, and correct spark plug numbers, thanks. The spark plugs already in the engine are NGK B7HS 10. Are those plugs correct?
rabidfish
Re: need info about Evinrude 6 Yachtwin outboard
The model number should be all any qualified evinrude/johnson parts salesman should need to find any part for that engine. <br /><br />The plug you mention is a replacement for the Champion QL78YC. This is not the correct plug for this engine. <br /><br />Try a Champion QL77JC4 or an NGK BR9HS-10<br /><br />Your engine is a 1985 6hp
