need info on a 9.9hp chrysler
willowkevin
the serial number is-9311a i bought this engine last year and its ok but im starting to have problems at full speed the engine seems as thought theres dirt in the carb float bowl but i think i can see a pump where can i find online pictures and info on this engine and also other peoples thoughts on this engine???????? thanx kev!
steelespike
Re: need info on a 9.9hp chrysler
Chrysler is OK, I wouldnt buy one.They were originally West Bend,purchased by Chrysler in about 64,became Force in about 84.<br /> All out of business.<br />Some parts can be hard to find and expensive.<br /> I wouldnt invest huge amounts of money in any of them.Routine maintainance no problem.A service manual would be a good start.<br /> Sounds like you need to rebuild the carb and fuel pump.And it wouldnt hurt to go through the fuel system from tank to carb repair and clean as required.Also if you havent done the impeller in<br />a while a new one would be a good idea.
scotiany
Try NAPA for carb rebuild kit and fuel pump kit. As for impeller, your best bet is probably EBAY. Your engine is a later model than '67. My manual only goes to '67 and all they list is a Chrysler 9.2 hp. I got points , condenser for my Chrysler at Boatingsolutions.com. They still have a lot of Chrysler parts.
FlyBoyMark
Ensign
I believe there is a little tiny fuel filter/screen on the inlet to the fuel pump(actually inserts into pump), jus looks like an adapter fitting for a hose. Check that too and try a different fuel line and tank....Those motors had points too I believe under the flywheel....AS aforementioned, manual is a must on this engine....
alcan
Hi Kevin<br />Take a closer look at the model #. I'm betting that it actually reads 93HA, This would make your motor a 1970 model. Unfortuneatly I don't have a parts manual for your exact model. How ever if you will post your email address I will try to send some pics and info that should be close enough to be of some help. Of course purchessing at repair manual would still be prudent.
