Re: Need info on a Gale 25 hp
That's a 1960 25hp Gale. It's a 35.7CID engine and functionally equivalent to the '56 30hp. You're engine shares a lot of parts with the Evinrude/Johnson "Big Twins". Going closest to most different, it would be 30hp, 28hp, 33hp, 35hp, '58-59 35hp, and then 40hp. They made these engines from the early 50s through the 80s.<br />So lots of consumable parts are available, some both aftermarket and OEM. Water pumps, gaskets, ignition components, seal kits, are all easily had. Anything durable can be found on ebay or at an outboard junkyard. You'd have to do some hunting if you were after a set of oversized pistons, but you would likely be able to find them.<br />Click my "man-next-to-house" icon - that's my 28hp. <br /><br />Fuel/Oil mix is 24:1 (use 87 octane gas and TC-W3 outboard oil)<br />Spark plugs are Champion J4C gapped at .030". Sometimes the J6C is worth a try for better trolling.<br />Lower unit fluid is OMC/BRP "HiVis" or other brand 90 weight outboard gearcase lube.<br /><br />If you need anything else, just ask.
