Re: Need info on seaking motor
Sea kings were built by a number of companies.
I don't find that number.A picture would help or If you could describe it we might be able to figure it out.Number of cylinders,what spark plugs,make of carb,color of powerhead,type of hood/cowl (steel,fiberglass etc.),air cooled(many fins on cylinder)twist grip throttle,remote or built in tank,Best guess at horse power and year,number of blades on the prop,fuel mix.
As far as storage add stabil to the fuel run to get treated fuel into carb or run carb dry.
Fog the cylinders with something like WD40,Change the lower unit lube.Store upright.off the floor.
