need info on valve adjustment 140 OMC engine
marcel crash
i am loking for some info on the adjustment for valve sequence
i replaced the head gaskit on the 1980 140 4 cylinder omc inboard engine
i am looking for te valve (sequence )oder to set the valves on #1 topdead center and #4 exc....
Don S
Re: need info on valve adjustment 140 OMC engine
Valve Adjustment
Engine Not Running
With valve cover removed, adjust valves when lifter
is on low part of camshaft lobe, as follows:
1. Crank engine with starter or turn over in normal
direction of rotation until mark on torsional damper
lines up with center “0” mark on timing tab, and
engine is in No. 1 firing position. This may be determined
by placing fingers on No. 1 valve as
mark. If valves move as mark comes up to timing
tab, engine is in No.4 firing position and should be
turned over one more time to reach No. 1 position.
No. 1 Cylinder - Exhaust and Intake
No. 2 Cylinder - Intake
No. 3 Cylinder - Exhaust
No. 4 Cylinder - Intake
2. With engine in No. 1 firing position as determined
above, the following valves may be adjusted:
3. Back out adjusting nut until lash is felt at push rod,
then turn in adjusting nut until all lash is removed.
This can be determined by moving push rod upand-
down while turning adjusting nut until all play
is removed.
4. Hydraulic lifters now can be adjusted by tightening
adjustment nut an additional 3/4-turn. Valve
lash should be checked after engine has run and
reached operating temperature.
5. Crank engine one revolution until pointer “0” mark
and torsional damper mark are again in alignment.
This is No. 4 firing position. With engine in
this position, the following valves may be adjusted:
No. 2 Cylinder - Exhaust
No. 3 Cylinder - Intake
No. 4 Cylinder - Exhaust
6. Install distributor cap, spark plug wires and coil
lead.
7. Install rocker arm cover; torque to 40 lb. in. (4.5
N?m).
marcel crash
thanks alot there guys use are alot of help, thank's for the info
