Need Link To Alpha 1 Lower Gear Case Drawing
Robbie Davis
Re: Need Link To Alpha 1 Lower Gear Case Drawing
I need the one like this drawing and part numbers
http://www.iboats.com/Mercruiser_St...ed_View/dm/category_id.268710--view_id.272967
I have mallory lower seal seal kit 9-74304 (18-2652)
I need to see where they belong in the unit
I know some are for water pump cause I got the water pump kit to.
(1) 18-2919 Water Pump to Gear Hsg. Gasket - replaces O.E. # 27-42631-1
(1) 18-3110 Grommet - replaces O.E. # 26-38970
(1) 18-2002 Oil Seal - replaces O.E. # 26-76868
(2) 18-2013 Oil Seal - replaces O.E. # 26-16977
(1) 18-2014 Oil Seal - replaces O.E. # 26-89238
(1) 18-2826 Water Pump Base to Gear Hsg. Gasket - replaces O.E. # 27-85610-1
(1) 18-2914 Lower Water Pump to Wear Plate Gasket - replaces O.E. # 27-85608-1
(1) 18-2915 Upper Water Pump to Wear Plate Gasket - replaces O.E. # 27-85609-1
(1) 18-2944 Seal Ring - replaces O.E. # 26-45577
(1) 18-2948 Gear Housing Plastic Flush Screw Gasket - replaces O.E. # 12-49221-1
(1) 18-7158 O-Ring - replaces O.E. # 25-30613
(1) 18-7159 O-Ring - replaces O.E. # 25-31534
(1) 18-7162 O-Ring - replaces O.E. # 25-33145
(1) 18-7176 O-Ring - replaces O.E. # 25-90011
(1) 18-7196 O-Ring - replaces O.E. # 25-38099
(1) 18-2154 Bushing, Shift Shaft - replaces O.E. # 23-30617A2
(1) 18-2076 Line Cutter Oil Seal - replaces O.E. # 26-12224
(1) 18-7426 O-Ring - replaces O.E. # 25-30271
(2) 18-2945 Gear Housing Drain Screw Gasket - replaces O.E. # 12-20260, 12-19183
