Need major help on Chrysler 60!!- Got model and serial #
clanton
Re: Need major help on Chrysler 60!!- Got model and serial #
May be 1885 up Charge coil putput at stator with DAV 210 volts, trigger 0.3, volts CD module (power pack) 210 volts.
clanton
carterjustice
Clanton, I don't understand,I am sorry to be some motor stupid, just need help.
clanton
What is motor doing, not firing, are you know pack is bad and need one. If sparking to plug problem, Take old plug gap to 3/16 groung to block, should have blue fat spark with snap, at cranking speed, do one cylinder at a time. If you have no spark one cylinder switch wire from good coil to coil with no spark, now spark coil ok. bad pack or sensor. Let me know what you get. You know my wife tells me the same thing.
