Re: Need more HP 90/115/140
Adding finger ports to a cross flow help it breath, keep it cool and helps overall combustion.
Here is a properly placed finger port:
Finger ports on a OMC Looper help scavenging through the bottom and mid range of the power band and are essential to making good power on these motors.
On a Cross-flow OMC they are more for reliability. The design of a Cross flow piston holds allot of heat in the dome especially when held at WOT For longer periods of time in proper tune. The finger ports in a Cross-flow help to move a cool intake charge under the piston and wrist pin bearing area. An area where not allot of flow takes place at high RPM’s. While they help a small bit with power if done right they are essential in an Xflow for reliability such as ModVP or endurance racing.
Finger ports pull the charge out from underneath the piston crown, thus keeping the dome cooler. Also, cleaning out the charge in the case, which helps the engine pull more volume. They should be higher than the transfer ports, but not higher than the boost port. A little lower than the boost port actually. And as far as not putting them to close to the ring gap, well its not like you will put them between the transfer and the exhaust. They should be right on the ring gap.
