Need more performance??? help
186captiva
I have a 1996 19 foot rinker with a 4.3 v6 does anyone have any suggestions for performance upgrades I can do besised get another boat or drop a v8 in it. thanks for the help.
Re: Need more performance??? help
Knowing Exactly What you've got to Start with,<br />And, How Far you want to Go, would Help........<br /><br />HorsePower Costs Big $$$$$$$$$<br />How Much Do You Want ??????????????????? :D
186captiva
sorry about that i guess more info would help It is a 1996 4.3 mercruiser with a alpha 1 drive. I dont want to tear the whole motor down but just want some ideas on what my options could be.
2bbl. or 4bbl. Carb. ???????<br />That's the Only Real Option, Without getting Into the Engine.........<br />the 4bbl. is worth about 25/30hp........
186captiva
I do have a 2 brl now so that is a option. What about exhaust manifolds or intakes?
You'll Absolutely Need a new Intake Manifold to bolt on a 4bbl. carb......<br />1996 is a transitional year.... <br />The Pre-Vortec motors have 12 bolts holding the Intake Manifold on........<br />The Vortec uses only 8 bolts....... <br />I'm Guessing, But you're Probably Not running in Salt over there in Ohio.....<br />You Could use an Aluminum Intake from a mail-order parts house..... <br />Or, a Better approach, Is to find a Mercruiser Cast-Iron 4bbl. Vortec Intake.............<br /><br />On the Exhaust side, If you're running Thru-Prop exhaust, That's Your Choke-Point.....<br />Just going thru-Hull is a Plus......But, Awlfully Noisey......<br />Headers are Big$$$$$$$$$$$$$$$<br />But, Available......
186captiva
I thought about headers or cut out's but that alot of cash when it might soung like crap since it's a v6.
Walt T
So...let me get this straight. You want more power yet you don't want to spend any money? 4bbl your best bang for the buck. Your current exhaust is already pretty free flowing, leave it alone. <br />If thats not enough, then always remember....There's no replacement for displacement.<br /><br />Horsepower always costs money.....when you install it, and when you use it.
mercrewser
You wont make any more power with open exhaust. And yes it will sound stupid. Its a v6. Go with the 4v or another boat with more power. You can make 225 hp if its a vortec. Stingray has a boat that does 60 with this motor. Thats pretty impressive. Boat is 19'.
Darian F.
Quick tip that costs less than 50$ and will help performance a little.<br />look at your transom assy. If you still have ribbed exhaust bellows ( the smaller rubber tube about 3in in diameter) you can install an exhaust boot(a half tube with a smooth bore )in it's place.<br />It is a little louder and works best on a v-8 but will help the 6 cyl<br /><br /> The boot is a merc part by the way.
Danny_Ocean
Exactly! That's what I tell the little snot-balls in their Honda's who try to race me.<br /><br />Dropping in a V-8 may be less expensive (or equal to) than trying to hot-rod your V-6.<br /><br />Then again, buying another boat (+ cash from your sale/trade) with power to suit your needs might be even more cost-effective.<br /><br />D. Ocean<br />Pompano Beach, FLA
