briboat
- Joined
- May 28, 2009
- 28
I have a 2004 Silverline ls1700 fiberglass bowrider 2008 Mercury 115elpt 4stroke,2.07:1 ratio.The boat has 14degree deadrise 21 gal tank and approx 2000Lbs +500Lbs for load.I experienced porpoising with almost no trim so added smart tabs which has reduced. Looking to replace prop after lowering motor 1 hole it helped with porpoising but reduced wot to 5400 .
current specs with 17p and dealer loaned 15 p black max aluminum 3 blade
RPM 17pitch 15pitch
3200 17 pitch- 20miles 15p- n/a
3500 17 p -23 15p 20
4000 17p -28 15p 23
4500 17p -34 15p 29
5000 17p -39 15p 33
5400 17p -42
5500 17p max 15p 38
6000 17p n/a 15p 43
6100 17p n/a 15p 44 max speed all readings are using speedometer ,sorry no gps
general purpose is to reduce porpoising, day cruising with tubing(watersports),normally 3-4 people boat and occassionally 2 tubers,holeshot is ok with 17 p 3 people,was much better with 15 p but seem to cavitate, vent and slip on hard acceleration.
Open to using stainless or 4 blade .
Any suggestions would be appreciated .Thanks Brian
RPM 17pitch 15pitch
4000 17p -28 15p 23
4500 17p -34 15p 29
5000 17p -39 15p 33
5400 17p -42
5500 17p max 15p 38
6000 17p n/a 15p 43
