Re: Need opinions an a 1987 165 hp in/out
Supercab:<br />There are some less than desireable characteristics in the 470/3.7Liter 4cyl engines. The charging system is one...but not insurmountable, another is the direct, cam driven water pump, again not insurmountable but costly to repair since the cam must be removed, not bad if it can be done without engine removal. ANother issue is the closed cooling system, but lots of engines have that. The older models use a 3 inch heat exchanger that was inadequate, the newer ones a 4 incher that works well.<br /><br />I have a 1989 3.7L, the 470 was the early version (1976 to 1984) of this engine. I converted the charging system ($365) when the water cooled alternator died. The alternator died from over heating, because the impeller in the lower unit broke down. It's critical for proper cooling in all closed cooling systems, very problematic for water cooled regulators. I've never had trouble with the cam seals, there are two (inner and outer) and when they wear, small amounts of coolant will leak, signaling time to repair, but it won't create an emergency.<br /><br />There are some real good points about the 3.7L...as Northern Eclipse mentioned, they are torque monsters, they're also very mechnically reliable. In a used boat...everything is dependent on price. You should be able to get a 19 footer in very good condition with a 3.7 for $3500 or less.
