Re: Need opinions on this boat,thanx...
Strike King,<br /><br />It looks a little rough. Maybe just the paint.<br /><br />Do this:<br /><br />1. Walk around in it and see if there are any soft spots in the floor/decks. If so, point that out to the seller.<br /><br />Fortunately, soft floors/decks are not hard to repair on an aluminum boat. The seller doesn't need to know that.
<br /><br />2. Lift the engine up to its full up setting. Grab the skeg of the engine and lift up and push down. See if the transom flexes. If so, that is a BIG deduct in the price. You can replace the wood in the transom, yet it IS a project. Not that hard, just tedious.<br /><br />3. Get compression readings on the engine. The cylinders should be over 100 psi and with 5-10 psi of each other.
