Re: Need part number of fuel pump to replace VRO for Evinrude 140 V4 1990
Hi Ken,<br /><br />Thank you for stopping by.<br /><br />I have my carb rebuilt already...not help. Then I changed the fuel pump and use premix gas ( pump part number is 438552. It has a pentagonal shape with 3 hoses. The manual says this pump is use for model 9.9 hp and up. I'm not sure that it has enough flow for my 140hp or not ). The problem was much improved ( good idle ). Only occasionally during WOT that it lost rpm and improved by pumping the primer bulb. Today I changed the fuel filter ( the old one just 3 months old). The problem is gone now. I think the pump that I've changed is working near it's upper limitation. No reserve pumping action to draw fuel through a semi dirty filter. I also observe that the fuel outlet is much smaller than the VRO pump. I wonder if I screw this outlet out and make the lumen bigger, the outflow rate may be improved. I may try doing this and I'll also try to find the right pump for my motor ( Non VRO ).<br /><br />Glad to here that you used to live here in Thailand. Here, Yamaha outboard market is stronger...a lot of spare parts. I think Evinrude is good so I'll try to keep my motor running. I start to stock parts and try to fix some problems by myself. I'm a doctor, not a mechanics but very much like to do this job.<br /><br />Happy boating !
