Twhjelmgren28
- Joined
- May 31, 2016
- 85
Hey all - first off; just completed bell housing and gimbal housing rebuild on the motor, so thank you to those who helped with that.
I have a 1985 16.5 fiberglass fish and ski boat that I inherited from my Grandfather. The boat has been a great runner and, as mentioned, I've been working on maintenance and getting it back into shape.
While working on it over the past month, I noticed a small (1' x 1' or less) mushy spot along the center of the floor near the driver's seat. I decided to cut into it. The plywood floor was a bit rotted - I'd say less than a square foot. I noticed the rot had crept up to the floor from the stringer.
Before I go any further, I'll mention that I think I know where the water crept in. The stringer is 2 plywood boards put together with fiberglass on the outside, however, the end near the hull was seemingly open (and/or didn't have any fiberglass) so any water between the floor and the hull was able to creep in through the end. I decided to keep cutting along the stringer (about a 6" width) and realized that the entire thing will need to be replaced. Luckily the stringer goes from just in front of the driver's seat to just in front of the engine compartment. The hull an everything else appear to be fiberglass:
I've never gotten into anything like this on a boat so looking for some advice and/or some good videos.
Since the floor seems pretty solid and doesn't look rotten (aside from the 1 square foot mentioned above), I'm planning on cutting the remaining 6" width to just in front of the engine compartment so I can remove the entire stringer. The entire length of the stringer is about 6 feet. That's about as far as I've gotten with my plan. Looking for advice on how to attack it - I'm feeling pretty good about the replacement of the floor itself but don't really know what I'm doing with the stringer.
Basically:
1. Am I on the right track and how should I go about putting the new stringer in?
2. Any good threads or videos that would give me a good idea of what I need to do?
3. Will I be able to do a stringer replacement without removing the entire floor? I'm trying to be as minimally invasive as I can.
*Also, I haven't done much research into it yet so hopefully I'm not jumping the gun too much by asking. Thought I'd go straight to the experts.
Thanks!
Basically:
Thanks!
