Re: need Pre-alpha upper seal replacement instructions
You'll be deep enough that you'll need a manual.Tools aren't that expensive.A special wrench for the cover nut holding the whole shaft assembly in,and a torque wrench to snug it up (200 lbs ft as I recall)
The manual will tell you where to watch out for the shims (DON'T loose any !)
You'll most likely need a new u-joint yoke (worn at the seal areas ) but that replacement is standard proceedure with the shaft out.
As for the manual,don't substitute.Get the real thing from Merc.
DHP
