highpowerdad
- Joined
- Feb 5, 2020
- 83
Hello all,
Boat is a 2005 fourwinns 190 horizon runabout, 5.0GXI VP 270 HP with SX drive.
I recently purchased a Solas 4 blade Titan 19 pitch, Solas PN 8653-141-19. With the ORIGINAL VP 3 blade SS 19P, and only me in the boat with ½ full fuel tank, was turning 5450 RPM WOT which was way over the 5000 max for the 5.0GXI. GPS speed was 52-53. With the Solas 8653-141-19, it now turns 4600 RPM with a speed of 50-51, so I am concerned when I load the boat up with more people, I will lose even more and bog the motor down. This seems like a big difference between 3 and 4 blade props, I was expecting about ~250, not 850? Is it just the difference in the blade design?
I was going to order an 8653-141-18, i.e. Solas titan 4 blade for VP in 18 pitch RH next, but that particular prop seems to be a unicorn, and I have not been able to find one actually in stock, though I am told at the end of Feb / beginning of March, they will be available. If my math is right and I am assuming the two Titans would be easy to compare, the 18 pitch would put me at about 4850-4900 which is about ideal. For a 17 pitch in that same prop which is more available, I think I would be back over 5000…maybe even 5150-5200. (estimated RPMs are based on achieving the same relative top speed of 51 MPH)
SO…my real question is, if I hold out for the 18 pitch, and get the 4900 when running light, what will happen when I put 4 or 5 people in the boat and am pulling tubes and skis and wakeboards…do I really want the 17 pitch, that may be a little underpropped when running light but more oomph when loaded. Is the 18 pitch enough of a step down or should I go with 2 steps…? I would like to stay with the pressed hubs since that is what I already have, it looks like I could get a Rubix HR4, but then I would have to use different thrust washers etc…if I have to change the props for some reason.
Thanks
Thanks
