Need prop for 84 mariner
someone11
I need a new prop for my 84 15hp mariner. I ordered one off of Iboats and it was not the correct one...the spines didnt match up (Correct number, just different sizes). I emailed IBoats and asked which prop to get since I wasnt sure and they said they didnt have a prop that fit my motor. The weird thing is on iboats they have for an 84 mariner 15 hp, a non through hub exhaust with pin drive. Mine is definitely through hub exhaust and 8 spline drive. The size of the prop is 9 1/2 x 10 1/2 and there is no part number on the prop. I may just end up sending it in to get it repaired. Any help appreciated.
steelespike
Re: Need prop for 84 mariner
While this is a prop question it is also a motor specific question.
The Mariner guys may have a solution.
I do know that some Mariners are Yamahas.
I also know on some brands of non thru hub motors you can use Thru hub props. Perhaps yours is actually a non thru hub motor
someone stuck a thru hub on.
someone11
Im pretty sure it is a thru hub motor but I could be wrong. It is all open down where the shaft is so I assumed it was thru hub. Ill try posting in the Mariner section, thanks.
steelespike
Your probably right.I'm just grabbing at straws for why the prop is wrong.
