need prop for 9.8MF 4 cycle Tohatsu 2013 Rocket rich
Sea Rider
Will depend entirely if original delivered prop with engine suits moving your current load & boating needs as expected. For that will need to check your max wot rpm you alone, lightly loaded, with an induction tach to know if original prop works top for that combo. That's not being under or over revving OB.
Happy Boating
rocket rich
last time I Checked it 5840 WOT which is as close as I want to be to 6000 WOT. with factory prop which I''m not sure what the number is?
TGuy
You can a get a list of props from the tohatsu website (http://www.tohatsu.com/accessories/prop.asp). It shows which prop comes standard with the various models. So depending on whether yours was short vs. long shaft, power tilt vs. non-power tilt, etc. you should be able to determine which was the "standard" prop from their prop chart.
rocket rich
Thanks, I'm having problems getting back in the boat .Had surgery on my spine and my mind doesn't work right yet. Nerve damage
Sea Rider
All portable OB's comes with medium pitch props. If that prop delivers near full wot rpm replace with same. Going one less pitch will over rev engine badly with current load, only good is moving more load while staying close to wot numbers. The current prop number must be stamped on prop's body, check.
Happy Boating
pvanv
TECHNOLOGY : 4-Stroke
Model : MFS9.8
Prop TypeLoad*DiameterPitchBladesStandard Equip.Part #Comments
ALUMINUM LIGHT 8.5 9 3 3B2B645170
ALUMINUM MODERATE 8.5 8 3 Y (short shaft models)3B2B645151
ALUMINUM MODERATE 8.9 7 3 Y (long shaft models)3B2B645140
ALUMINUM HEAVY 8.7 7 4 Y (Power Tilt, long shaft models)3B2B645120 HIGH THRUST
ALUMINUM HEAVY 8.3 6 3 3B2B645126
ALUMINUM HEAVY 8 5 3 3B2B645125
ALUMINUM HEAVY 8.7 5 4 Y (ultra-long shaft models)3B2B645110 HIGH THRUST
