Need prop recommendation for 170 F&S with a Johnson 115
Berta
I have a 1997 170 Fish & Ski Sunbird with a 115 Johnson V4 2-cycle of the same year. We use it to ski and other water sports. It is equipped with an aluminum 3-blade, 14x17 prop with moderate wear and tear. WOT should be between 4500 and 5500rpm max. The motor is running fine but it is a little slow out of the hole. It tops out in the low 40's when trimmed out a little higher than necessary (it hits the throttle stop at around 5400 rpm +/-). I would like to improve the hole shot and hopefully not lose any more on the top end. Any recommendations on the prop pitch, rake, cup, etc.? Thanks in advance.
tnduc
Re: Need prop recommendation for 170 F&S with a Johnson 115
If you post in the Evinrude/Johnson section you will have many more responses.
