Last night discovered the water pump (on the front of the block) was leaking pretty heavily from the bottom weep hole. I was able to find a replacement water pump this morning and the family patiently waited while I installed the new pump. Put the motor on the muffs and started the motor to make sure everything was good before we left for the lake. A few seconds after the motor started I realized I have a serious problem. There is no water exiting the sides of the drives with the exhaust. It appears I have no water flowing through the system. What is wrong. No problems before the new water pump and everything is back on correctly. Any ideas? Now I hope I don't have impeller issues since there was no water flowing.
