Hi guy's
HOW are you ?
Well i have a 40hp johnson modle rds-26s serial # c397061
I was woundering if and how i could replace the old close line steering systeam with a rack or tube systeam or would the cost be worth the bother?
Mybe a used steering systeam if any one has a line on one.
The other q is i have not owened the boat for two long but i am learnig fast about up keep on the motor i have doubt about the prev owner mantanice skill so i am replacing a few things for my peace of mined but i have noticed a leak at the very bottom of the motor were the forward and reverse gear are around the screwesthat connect the halfs of the unit together. do i have to drop the lower unit to see if the gaskethas give out or can i just unscrew those bolt's with a robertson head and check the gasket that way or would i screw up the forword and rev and mybe pinion gear
any help at all would be gladly recived take care
HOW are you ?
