Need some help 1995 force 120
Btrent1999@gmail.com
Need to put a water pressher Gage on the motor any help would be all some don,t know where to start what Gage to get or anything thx btrent
jkoppe73
Re: Need some help 1995 force 120
Much easier and much less expensive to install a telltail, see the sticky (FAQ) at the top of this forum.
roscoe
http://www.ebay.com/sch/i.html?_nkw=outboard+water+pressure+gauge
Any one you like.
0-30 psi.
2" diameter, or 3", Take your pick.
Drill hole, install gauge in dash.
Run 1/8" plastic tubing to motor.
Attach to motor at small plug located on top of thermostat housing.
You will probably need to buy a brass hose bib at the hardware store for $3.
Wire the light in the gauge into the existing gauge lighting circuit if you want the light to work.
