Pokertrampp
- Joined
- Sep 17, 2009
- 279
I have a 1988 120hp Johnson. It has been sitting since last October, and had trouble strating and running. So I was going to rebuild the carbs but i found a set of rebuilt ones on ebay, they looked new to me did not even smell like gas. Well, I installed them and now it runs even worse, according to my manual there is no High/Low speed adjustments on these, is this correct? These are the carbs with aluminum base with plastic body 2 carbs per base/per side. all cylinders have 100+ psi and seem to be getting good spark. so I am fairly sure it is a fuel problem. I am just not sure what to adjust at this point. I have done the link and sync but I am planning to re-do it again just to verify I did it correctly. any advice would be greatly appreciated.
